$16.00
Walnut Veneer, with 3M Tape (Finished)
Size
Regular price $16.00
$16.00
$16.00 Sale price
Approximately 2/100" thick
Proofgrade Walnut Veneer lets you capture the rich, chocolate brown look of real walnut hardwood as a thin slice. Create custom keyboard keys, elegantly label your spice jars, or make custom name tags or menus for your next special event. The micro-thin walnut layer is a rich, chocolate brown with hints of purple.
About Proofgrade Veneer:
Proofgrade veneers are flexible, thin slices of natural solid hardwood with a premium 3M adhesive peel-and-stick backing. Veneer is ideal for stickers, and can transform a laptop into a work of art. It’s also stunning layered over acrylics and inset into contrasting plywoods and hardwoods. We match our hardwoods, plywoods, and veneers, so you can combine all three for a consistent and professional look. Each board is coated with a furniture-grade semi-gloss finish and protected with a removable paper sheet. As a result, each print looks incredible straight out of the laser. The beautiful hardwood outer layer is a natural product, so each board will have a distinctive pattern and grain all its own.
